- Joined
- May 2, 2020
- Messages
- 228
This is my current EFI and problem description.
Build uses 0.6.4 build of OC that Shannee created.
Main issues:
- during normal boot, window server halts on login (or login never displays, it's black screen) but machine has otherwise booted successfully
- when using safe boot, I can login even thouigh login window is all garbled displaying dynamic background picture:
![login-garbled.png login-garbled.png](https://forum.amd-osx.com/data/attachments/1/1841-7666fdceeb3e8824787a3ae7e4ea6258.jpg)
But it logs in fine, everything works as it usually works in Safe mode. Console app shows watchdogd killing windowserver which got into endless loop.
I am using HDMI connection, not Display Port. GPU works just fine, I tested it heavily in Windows 10, there are no issue with it.
The EFI has entire setup, if anyone has ideas – please take a look.
Main issues:
