It is more likely to be related to your USB configuration.
You have USBPorts.kext, USBToolBox.kext and UTBMap.kext in your OC/Kexts folder.
You don't need or want USBPorts.kext and UTBMAp.kext in the same setup. They do the same thing, or should do the same thing, i.e. activate the same ports. In your case this is not true, as you have a couple of discrepancies, with ports set with different connector types in the two info.plist's.
Hopefully the reason the USBToolBox.kext and UTBMap.kext are not enabled in your setup is because you realised the ports weren't correctly set in UTBMap.kext. PTXH USB controller ports, discrepancies highlighted
XHC0 USB controller ports, discrepancies highlighted
However, I have my doubts that the USBPorts.kext is 100% correct. You have added Comments to describe which port is activated by each entry, which is great. Unfortunately, we don't know which motherboard you are using, so we can't check to see if the physical port comment corresponds with the port connector type you have set.
I would recommend the following:
Run through the USB ports with a pair of USB pen drives, to check that each port is set correctly.
Pay particular attention to the PTXH Type-c port (HS02 & SS02) , which you have set as 'Type-c+sw' (9). Use the screenshot below to help.
USB connector types.
Remove any unused kexts, drivers or tools from your OC sub-folders.
Then use Corpnewt's ProperTree plist editor to take a 'Clean Snapshot' of your OC folder, so all the redundant and obsolete kexts, drivers and tools are also removed from your config.plist.
i'm so excited to receive your reply in the middle of the night(UTC/GMT +8),
actually i build the usbports or usbmap because i just learned the relevant entry-level technology from Chinese video websites
and please forgive me there may be some problems in my English communication with you
unfortunately, in China, technical discussions about hackintosh are not public, although some video bloggers have produced videos that can be understood by more people
ok,leave out the nonessential words,about my posted ,lack a lot of important information
about usb build, usbports are more accurate than usbmap(motherboard:TUF Gaming B550M Plus-WIFI)
except Hub controller,the other ports have been correctly identified
If the port doesn’t change why do you have two Type-c ports shown? One appears to be set as USB2 the other as USB3, that indicates to me that they should be set with the Type-c (10) connector type.
