Ryzen 5800x with gtx 1070TI
nongrata23
Hello, i need some help if possible!
My specs are the following:
AMD RYZEN 5800X
X570 AORUS ELITE
32GB
NVIDIA 1070TI
nvme or ssd
I know the highest version is HIGH Sierra, any guide were to start with this for my particular components?
Thank you
Starting point is reading and then reading again the Dortania OpenCore guide.
Then configuring an EFI for your system. So the components in your motherboard/case are provided with the correct drivers/kexts/SSDT's etc.
Then configuring a config.plist for an 8-core X570 system.
Shortcut is to find a user with an identical system and use their EFI as a base for your own. The search function on this site can be helpful with this option.
