Ryzen 2700x, ASUS PRIME X370-PRO, Rx 580, Ventura 13.2, OC 0.8.8
Aries
CPU: Ryzen 2700x
GPU: ASUS ROG STRIX RX580 8GB
RAM: Corsair Vengeance PRO RGB 2x8GB DDR4 PC4-25600 CMW32GX4M2C3200E16
Motherboard: ASUS PRIME X370-PRO
Sound :Realtek® S1220A
SMBIOS: MacPro7,1
Don't forget to set your parameters
Bonus in the tools folder of the application to show the temperature and load of the processor and video card RadeonGadget and AMD Power Gadget. Just drag and drop into the applications and run... Added kext to support third-party bluetooth adapters.
Wallpapers
View attachment macos-monterey-stock-black-dark-mode-layers-5k-6016x6016-5889.jpg
Biggy
Hey Aries, thank you for posting this.
Do you still use the same MB ? Have you upgraded to Ventura and OC 0.8.6 ?
The first screenshot in post #1 shows the Ventura Desktop image, the System Information says it is running Ventura Beta release, so I would assume the recent GM release of Ventura works.
Biggy
I've seen that he has Ventura (Beta) installed but my question is if he has updated to last version of OpenCore and the latest version of Ventura (Not Beta)
Mikyan
Hola gracias por el aporte crees que funcione con
ROG CROSSHAIR VI HÉROE X370
AMD RYZEN 9 3950X
saludos
Biggy
Hi @Aries ,
do you still have this Motherboard ? If yes, do you mind to share with us the last EFI for OC 0.9.5 or later ?
I've updated OC to 0.9.5 and then updated Ventura to the latest version. after the second boot I cant boot anymore (just stuck on boot loop).
I still can't find any solution.
Thank you in advance.
