Hello everyone, I have the Aorus ProWifi X570I motherboard with an Intel wifi card.
I would need to know if it could be replaced by some "Out of the box" like the Fenvi.
Regards, and thank you very much.
Hola a todos, tengo la placa madre de X570I ProWifi de Aorus con una tarjeta wifi Intel.
Necesitaria saber si se podria sustituir por alguna "Out of the box" como las Fenvi.
Un saludo y muchas gracias.
If you want to retain but disable the Intel Wifi/BT card and use a PCIe adapter card with a native Broadcom WiFi/BT card then the PCIe section of the Wireless Buyers Guide contains these options.
I use a PCIe wireless adapter in all my desktop hacks, with an Apple Broadcom WiFi/BT card (6 desktops dual booting Windows 10/11 and macOS, plus a HP Server on Monterey). I have the full range of standard WiFi/BT dependent Apple services working on all of them. Using a mix of BCM94360CD, BCM943602CS and BCM94360CS2 Apple WiFi/BT cards.
The PCIe adapter method requires a spare PCIe x1 slot plus a spare USB2 motherboard header for the BT module to work.
The Fenvi cards can be a bit hit and miss when it comes to working out of the box (OOB). Not from my own experience but from others I have helped on this and other Hackintosh sites. But they may be economically better than purchasing a PCIe adapter and a separate Broadcom WiFi/BT card.
I have used a couple of the adapters shown in the link below, which I purchased from Amazon UK. Although I didn't pay anything like they are asking for these adapters now.
The BCM944360CS2 requires 2 x Antenna, it is slightly slower than the other cards due to the reduced MiMo output. It was used by Apple systems in 2013- 2017.
