- Joined
- Nov 9, 2023
- Messages
- 5
EDIT: Solved! see the replies below for the detailed explanation.
Need help with installing macOS on a Razer Blade 14 laptop with a Ryzen 9 5900HX and an RTX 3060. I know 3060 isn't supported so I'm trying to use the Radeon iGPU with NootedRed. Since the original wifi card in the laptop wasn't supported, I changed it to an Intel(R) AX210 (WiFi 6E)
So basically I've already spent 12+ hours on this but I'm stuck on issues and have no idea what is wrong anymore
Not able to boot to the installer. I was stuck on "IOAPIC: Version 0x21 Vectors 64:87" for a long time as seen below
But I added "cpus=1" to boot-args and got quite a bit further (But I don't know if this is the correct approach) and now stuck on "IOPCI Configurator Waittime is 900" as seen below
I have no idea where to go from here... Any help is greatly appreciated!!
