Solved Processor: Unknown
jxad
Im really struggling to change the CPU name, i try to edit AppleSystemInfo.string from /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/English.lproj/
Can copy the file out but can't move the edited one into the folder, even as root.
Tried some scripts from the web.
https://github.com/corpnewt/CPU-Name/blob/master/README.md This one not working, probably for unknown SIP config.
You need SIP disabled and copy with Terminal using sudo.
sudo cp -Rf /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/English.lproj ~/Desktop
sudo cp -Rf ~/Desktop/English.iproj /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/
jxad
Thanks man, it worked
