Hello. I installed Hackintosh for the first time by carefully following the instructions on the OpenCore website. Surprisingly, almost everything works quite well.
But sometimes, for unknown reasons, some applications, settings, and the browser freeze. Most often, this happens when I try to go to System Preferences > Keyboard > Shortcuts.
And when I just visit the Gmail login page.
I have not yet found a law for this phenomenon. It looks like it starts to happen randomly. After a reboot everything starts working fine. This may not happen for several minutes or several hours. I can safely work at the computer, after which it can start again at any time until the next reboot. Even now, as I wrote this, I went into the keyboard shortcuts settings several times and everything was fine, but just now it happened again. The settings window just freezes and does not react to anything and I need to force close it. If I now try go to the Gmail login page, my browser will also freeze.
My specs:
Motherboard: Asus Prime B450M-K II
CPU: Ryzen 5 1600X
GPU: RX 570
If you need any logs, then write what and how to get them, and I will send them to you. It's just that I'm using macOS for the first time and I don't fully understand what's what here.
My specs:
CPU: Ryzen 5 1600X
GPU: RX 570
