Possibly. As for the system performance well good for you! On my B550 my system simply flies. Yes it is that much quicker. It may be because we have the correct configs in place so the system picks it up that much quicker. I mean did also try to optimise the APFSTrimTimeout timing so there's that. But yes it is a fast system, and a very enjoyable one to use at that.@Middleman I just finished reinstalling to the new SSD and the boot was incredibly fast. Much faster than I ever imagined. I use a SSD for boot for my Windows too but I wasn’t expecting such a massive performance change. I am using a Samsung 970 EVO plus. Also, I’m not sure why, but the wifi is incredibly faster. There was less time needed to connect to the Wifi and my wifi speed was hitting 190 mbps. Could the Hard Drive needing more power to physically run, be draining too much power from the system that it was causing problems ?
I didn’t know about that Kext and it really wasn’t too much of an issue for me. I didn’t realise it was that slow before. If I hadn’t upgraded to a SSD, I probably would have researched the Optimisation.Possibly. As for the system performance well good for you! On my B550 my system simply flies. Yes it is that much quicker. It may be because we have the correct configs in place so the system picks it up that much quicker. I mean did also try to optimise the APFSTrimTimeout timing so there's that. But yes it is a fast system, and a very enjoyable one to use at that.
Right. Well not that's not a kext - it is a quirk setting in the latest versions of OC (SetAPFSTrimTimeout). As for the Bluetooth, best way to check is online support for your motherboard's BT interface under the motherboard's support website. It should tell you what card you have based on the drivers provided. If it is Intel or Broadcom you'll need the drivers set as I've mentioned before. Some of the kexts may need updating if they are not working with the present build. Broadcom cards are in my experience a little bit more trickier to configure as its drivers are defined by Apple-native and non-Apple-native. Non-Apple-native tend to use the BRCMPatchRam3 (for booting Catalina and newer OSes onwards) in addition to BRCMFirmwareData. Native cards generally do not need the kexts. However newer BT cards not detected by BRCMPatchRam3 may require firmware extraction from Windows drivers. Broadcom cards on Monterey will also require use of Bluetoolfixup.kext.I didn’t know about that Kext and it really wasn’t too much of an issue for me. I didn’t realise it was that slow before. If I hadn’t upgraded to a SSD, I probably would have researched the Optimisation.
My Bluetooth isn’t actually finding anything in the searching. I’ll need to check if I have the correct Bluetooth fixes in my EFI. Everything else is working great.
