Please help ! BCM94352Z Wifi not work
vin
Hi
Here is my hardware list
CPU:3700X
MB:ROG Strix B450-I Gaming
M.2 SSD:SN750 500G
RAM:ADATA 16G/3200 X 2
GPU:RX560 4G
WIFI/BT NGFF CARD:BCM94352Z
I add AirportBrcmFixup.kext to my OC/Kexts/
Boot-args set brcmfx-driver=2
Wifi still not work.
BT works fine.
Please help me to fix the wifi issue.
  1. Screen Shot 2020-12-24 at 10.36.18 PM.pngScreen Shot 2020-12-24 at 10.41.20 PM.pngScreen Shot 2020-12-24 at 10.37.05 PM.pngScreen Shot 2020-12-24 at 10.36.40 PM.png
atanvarno
Which version of brcmfixup? Since 2.0.8 they split that kext into multiple ones, so you may need additional .kext referenced:
Remove injectors for AirPortBrcm4360 and AirPortBrcmNIC from main Info.plist and move them into separate plugins AirPortBrcm4360_Injector and AirPortBrcmNIC_Injector (kexts with plist only). Under 11.0 (Big Sur) plugin AirPortBrcm4360_Injector.kext must be blocked by MaxKernel 19.9.9 or just removed, otherwise it will block loading of AirPortBrcmNIC since class AirPortBrcm4360 is unsupported.
(from 2.0.8)
So keep kext you have and try adding another kext entry below it, either AirportBrcmFixup.kext/Contents/Plugins/AirPortBrcm4360_Injector.kext or AirportBrcmFixup.kext/Contents/Plugins/AirPortBrcmNIC_Injector.kext and test with one then another (if it does not work with first).
wintersun52
Had the same problem, it is caused by the AirportBrcmFixup.kext I fixed it by going to kext folder click on the kext and show package contents go to plugins and delete AirPortBrcm4360_Injector.kext, then do a clean snapshot.
