OpenCore doesn‘t „reboot“ to the BootPicker
lxnx.fr
Hey guys,
I have been trying to install BigSur now for quite a time but it seems that it is always the same error.
OpenCore, after it‘s loaded, doesn’t want to ReRun/Reboot to the BootPicker.
I tried to change several things in the BIOS to get in any way to the installer... but it’s always the same.
My HP-Laptop (AMD A4) comes to the BootPicker.
If someone has any idea what I could do, please let me know.
attached a installation pic, installation logs in the EFI, BIOS pics and the the edition-installation
greetings
  • efi-opencore.rar
saufisapph
I have the same problem and my pc spec are nearly identical to you. Happens to me quite sometime ago and only after i ran initial installations on the drive. The next reboot always fail to boot opencore from USB. The bios just didn't find the USB drive to boot. Found a workaround, remove all the drive in your pc, then try to boot with USB.
If it WORKS, select Install Big Sur (External) and wait until you reach mac installer, then shut down. Reinstall all the drive, insert USB installer and restart your pc. Now, it should be able to boot from USB. Select Install Big Sur (External) and wait until you reach mac installer. Then, open disk utility, erase the install target drive but make sure you select APFS as filesystem. After that, quit disk utility, and proceed to install. Upon reboot, your pc should boot from USB and you can continue with installations. Hope this help.
If it DIDN'T WORKS, sorry, but i can't help you.
