OC 0.68 kernel panic
baronerosso
OpenCore 0.68 creates a kernel panic with immediate reboot after about 15 seconds of use.
I post my config.plist and the KP report.
With OC 0.67 I have no problems (only small things that have always plagued me, but from login onwards the pc is perfect).
I tried to use only SSDT-EC-USBX-DESKTOP.aml and delete entries in DeviceProperties, tried using algrey patch instead of shaneee, not using OpenCanopy, remove unfairgva=1 from boot-arg but ... the result doesn't change.
Help
panic(cpu 0 caller 0xffffff801d4fda11): CPU 23 has no HPET assigned to it
Backtrace (CPU 0), Frame : Return Address
0xffffffa0bd90bc60 : 0xffffff801c0bab4d mach_kernel : _handle_debugger_trap + 0x3dd
0xffffffa0bd90bcb0 : 0xffffff801c1fd7e3 mach_kernel : _kdp_i386_trap + 0x143
0xffffffa0bd90bcf0 : 0xffffff801c1ede1a mach_kernel : _kernel_trap + 0x55a
0xffffffa0bd90bd40 : 0xffffff801c05fa2f mach_kernel : _return_from_trap + 0xff
0xffffffa0bd90bd60 : 0xffffff801c0ba3ed mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffa0bd90be80 : 0xffffff801c0ba6d8 mach_kernel : _panic_trap_to_debugger + 0x268
0xffffffa0bd90bef0 : 0xffffff801c8bef9a mach_kernel : _panic + 0x54
0xffffffa0bd90bf60 : 0xffffff801d4fda11 com.apple.driver.AppleIntelCPUPowerManagement : _pmInitThread + 0x2c0
0xffffffa0bd90bfa0 : 0xffffff801c05f13e mach_kernel : _call_continuation + 0x2e
         com.apple.driver.AppleIntelCPUPowerManagement(222.0)[521F8CE9-4706-3AC7-9504-03354380846E]@0xffffff801d4f7000->0xffffff801d514fff
Process name corresponding to current thread: kernel_task
Boot args: keepsyms=1 debug=0x100 alcid=1 agdpmod=pikera unfairgva=1 chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
20D91
Kernel version:
Darwin Kernel Version 20.3.0: Thu Jan 21 00:07:06 PST 2021; root:xnu-7195.81.3~1/RELEASE_X86_64
Kernel UUID: C86236B2-4976-3542-80CA-74A6B8B4BA03
KernelCache slide: 0x000000001be00000
KernelCache base:  0xffffff801c000000
Kernel slide:      0x000000001be10000
Kernel text base:  0xffffff801c010000
__HIB  text base: 0xffffff801bf00000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 90609191925
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x0000001518ba8df3
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x00000014e4c6db9b 0x0000000000000000
Here's your issue ;) Change that and it should work just fine.
baronerosso
how stupid I am, I checked it 100 times without seeing it !!
TKS
