Network issue despite detecting Hardware
Deleted member 4462
I am tring to install catalina on
My ryzen 5 1600
16gb adata 2600mhz
Gigabyte ab350 gaming 3
But
There is some
macOS installer needs internet connection to install macOS.
Please help.
In solving above i messed up config.pliat and much more. And end up with more error.
Which i will fix after some time.
All i need is your help fixing network issue mentioned above.
I used to have that board. Include this kext for LAN and make sure you include it in the config.
  • RealtekRTL8111.kext.zip
Share your config and I'll take a look.
Deleted member 4462
here you go .
  • Kexts.7z
  • opencore-2020-08-25-154302.txt
Try this. If you get an error share an image of it.
  • config.plist.zip
NameDropper90
Hi, i have the same problem. What do you have edit in the config.plist? I've tried the latest RTL8111 but i get the no internet connection error.
NameDropper90
Deleted member 4462
Try this. Boot to the installer, Run Terminal and type this command, ntpdate -u time.apple.com
Now try run the install.
ntpdate has been replaced with sntp in Mojave. Try sntp -sS time.apple.com
Deleted member 4462
FINALLY INSTALLED USIN horndis.kext.
but no audio in macos olus it is buggy slightly with unnatural graphics.
still happy that i installed MACOS
