Need help
Falcon
I would try removing that section from your Config.plist's DeviceProperties. As it may not match with your WiFi/BT card. Different laptops are provided with different WiFi/BT cards. Even later revisions of the same laptop can have different components. So this may be preventing your WiFi/BT card from working.
Your laptop won't have a Realtek 2.5GB ethernet controller. It will have a 1GB controller, it just may not be a Realtek Ethernet controller. The /EFI/OC/Kexts folder you linked contains the normal RealtekRTL8111.kext for a 1GB ethernet controller. If you have an Intel Ethernet controller in your laptop the Realtek kext will be useless.
The best thing you can do is boot in to Windows or a Linux Live USB/CD and confirm the devices present in your laptop. Without doing this you could spend a lot of time searching for the wrong kexts/drivers.
Falcon
if i look on the hp website it tells me this ( 8168C adapter) sp71892.exe
Falcon
see this also:
Definitely remove that from the DeviceProperties section in your config.plist, as it is probably the cause of your Ethernet controller not working. You have the correct kext in your OC setup. So no need to change that, unless you want to try another kext.
What does Windows say about your Ethernet controller, .i.e. what name does it apply to the controller?
Falcon
i found the issue with hackingtool. the driver is not loaded if i look under extensions.
it is not green. But how to fix it?
It show RTL810xE PCI Express Fast ethernet controller ,
Ethernet, PciRoot(0x0)/Pci(0x1c,0x5)/Pci(0x0,0x0)
(I deleted two previous messages , reason too much confusion for everyone)
For the 100MB Ethernet controller you need an older kext. Try the kext attached below.
  • RealtekRTL8100-V2.0.1.zip
Falcon
it seems like to work. Tomorrow i inform you for the result. Thanks!
Message for today. YESSSS everything works.
Edhawck thanks for your great help!
