Need help with BCM943602CS bluetooth
quiver
I'm currently running Catalina OS 10.15.4 (19E287) through opencore 0.5.7
current specs:
CPU: Ryzen 3 1300x
Mobo: ASRock B350 PRO4
GPU: RX 570 4GB
I just got a this card recently, Wi-Fi & airdrop from my phone works fine out of the box, but I'm having some issues with bluetooth
airpods (1st gen) is detected by the card but it just won't connect, ironically the card works with my generic brand BT earbud (audio is somewhat choppy even though I'm sitting very close towards the antenna)
airpods work fine with other devices.
Please let me know if you need more info, any tips/ insights would be very much appreciated
RyzeCooker
Just to be sure, the card is plugged into an internal usb-port on your motherboard?
quiver
yes, pretty sure I plugged it to the slot that says USB on the motherboard
I reckon bluetooth won't turn on at all in the first place if it's not plugged to the internal USB port ?
RyzeCooker
I'm not sure to be honest. 🙃 I just thought it might report hardware but not allow for actual transfer or something. I have a wifi/bt card but still need to install it. Did you get any further with yours?
quiver
I'll probably just ignore it since BT works with everything else other than my airpods
so far I've got it to work with:
  • an iphone
  • VIDVIE BT earbuds
  • Sony Dualshock 4 controller
might try connecting with a TP LINK BT dongle later
4rico
Saat ini saya menjalankan Catalina OS 10.15.4 (19E287) melalui opencore 0.5.7
spesifikasi saat ini:
CPU: Ryzen 3 1300x
GPU: RX 570 4GB
Saya baru saja mendapatkan kartu ini baru-baru ini, Wi-Fi & airdrop dari ponsel saya berfungsi dengan baik, tetapi saya mengalami beberapa masalah dengan bluetooth
airpods (gen ke-1) terdeteksi oleh kartu tetapi tidak dapat terhubung, ironisnya kartu tersebut berfungsi dengan earbud BT merek generik saya (audio agak berombak meskipun saya duduk sangat dekat dengan antena)
airpods bekerja dengan baik dengan perangkat lain.
Tolong beri tahu saya jika Anda membutuhkan info lebih lanjut, tips/wawasan apa pun akan sangat kami hargai
update oc realase dan kext. hey bro give you send me efi please. your mobo same with me. Thx
