Need Help Upgrading from Sonoma to Tahoe — EFI Stuck During Boot
xaxey
13
AMD Ryzen 5900HX
I've been trying to get macOS Tahoe running on my Hackintosh laptop, but I'm running into issues. I attempted to upgrade my existing macOS Sonoma setup by replacing my EFI with one that supports Tahoe. Unfortunately, the system gets stuck during boot, and I can’t get past that point.
I've attached my current EFI folder and a screenshot of the error I'm seeing on screen. I’ve double-checked my config.plist and tried updating all the required kexts and OpenCore, but I might be missing something.
Any help or suggestions would be greatly appreciated. Thank you in advance!
Specs:
Laptop: Asus TUF Gaming A15 - FA506QM
Processor: AMD Ryzen 9 5900HX
dGPU: Nvidia RTX 3060
RAM: 16gb
    EFI.zip
Reactions: ccphuc
You might need to have a look at fixing your USB ports as Tahoe has some different requirements compared to Sonoma and earlier.
Specs:
RAM: 16gb
disable SMCAMDProcessor.kext ,USBToolBox.kext ,UTBMap.kext, path amd kenel 25.99.99
