Need help trying to installing Tahoe in Ryzen 5 3600x + rx 580
Nox_99
Ryzen 3600x
Dear Guys,
I m trying to install Mac Tahoe in my Pc. But Stucked in this error screen gone black.
Specs:
processor: ryzen 5 3600x
Gpu : sapphire rx 580 8gb
Motherboard : gigabyte b450 auros pro wifi
Wifi+ Bluetooth: Intel
If you have WhateverGreen.kext in your OC setup, try disabling it for the duration of the Tahoe installation. As it is known to cause issues with the Tahoe installation process.
It can be enabled once you reach the Tahoe desktop, so full graphics acceleration is reinstated.
I tried the Same but still didnt get any Success. Could you plz look into my efi and give any suggestion what should try next.
Only issue I see in your EFI is the use of UTBMap.kext, UTBDefault.kext and USBToolBox.kext. Those kexts won't work in Tahoe.
You need to create a USBMap.kext in macOS Sequoia or Sonoma using the latest script from Corpnewt's Github Repository.
Bro so the only option left is that i have to first try sequoia installer and create usbmap.kext then i move towards tahoe right.
FYI i m installing hackintosh using imac recovery file
Yes, installing Sequoia and creating the USBMap.kext before updating to Tahoe would be a good path forward.
