Need help for Sonoma or Sequoia
hinkin
62
AMD Ryzon 9 7950X3D
Hi everyone! Can somebody create EFI for Sonoma or Sequoia OpenCore 2.2.0
Ryzen 9 7950X3D
Gigabyte X870 AORUS ELITE WIFI7
RAM 32Gb DDR5 5200
AMD RX590 8Gb
The SanDisk drive would be a good option as a macOS boot drive. As would a Western Digital SN580, SN5000, SN770 or SN850X.
Check you have enabled the ‘DOCP or EXPO’ option in your bios. This is to be found in the Overclocking section of the bios. This is the AMD equivalent of Intel’s XMP, where memory modules can run at faster speeds than their base speed.
Have you got any clue how to turn on the Bluetooth or it is wifi integrated with gigabyte and not compatible with OSX
It will be integrated with the WiFi. So the Realtek BT probably won’t work. You need to swap the Realtek card for a compatible Intel or Broadcom WiFi/BT card.
Have a look at this guide for ideas on which Broadcom M.2 cards will work in macOS.
Here is a list of Intel cards that are compatible with AirportItlwm and Itlwm.kext.
Any of these cards will also require a specific USB port to be active and set as internal (255) in your custom USB kext (UTBMap or USBMap), for the Bluetooth device to work.
Reactions: hinkin
Hi, i have ACASIS 40Gbps USB 4.0 SSD Case Thunderbolt NVME M2 Enclosure. Could you please help me as I can't see it when it's plugged in?
Thank you!
Thank you!
Does it work in other operating systems? If it does it's likely you have not properly mapped your USB port(s) so it will function properly.
