Need Help at building the correct EFI for ‎AMD Ryzen 7 5800H!!
JackSparrow47
I am not able to reach atleast GUI Installation on my system....
I attached my final EFI with all editing done using dortania's user guide
Since I used the OpenCore-Debug so I also attached the log
I have Windows 11 Installed and wanted to dual boot MAC OS
For My BIOS :- Secure boot is disabled
My Laptop:- HP Victus 16
Its Specs:- AMD Ryzen 7 5800H
NVIDIA Geforce 3050TI 4gb
  • opencore-2022-04-26-235156.txt
The Nvidia RTX 3050 TI is not supported in macOS.
As your laptop uses an AMD CPU and it doesn't have a compatible discrete graphics card you won't be able to run macOS on your Laptop.
JackSparrow47
But what about the integrated AMD Raedon graphics?? If you got some time then please read the log and let me know the root cause.
The integrated AMD graphics are not supported in macOS. Never have been and never will be.
