- Joined
- Feb 15, 2024
- Messages
- 19
I've reached the point where I need to get some help. I've been working on a new build with the hardware in my profile. @leesurone directed me to @Kubokun has he as similar hardware. His EFI helped me through a hurdle I was having with constant KPs - corrected for my processor, usb map, and GPU spoof. When I first used the EFI I was able to get to the installer from Catalina through Ventura.. I don't have the right WLAN chip yet (on order) so I was trying to get the Intel i-225v LAN card working. I can't proceed with the install without web access.
I was looking through several forums and saw that it was supposed to have native support in Sonoma. I swapped out the base image for Sonoma and booted up. I got thru the picker and then hit a" OCB: install image failed unsupported". It now does it with every macos. I'm resetting NVRAM between each boot. It isn't helping. Ive read through the troubleshooting section of the guide. Those suggestions didn't work in addition to I don't have a security violation error with the load failure. There are only a couple of mentions on this site the one guy that was having an issue never posted back if it worked (guessing yes because he was never heard from again).
I changed around pretty much everything I could think of that I changed in the config.plist provided to the point where I went back to the original EFI from @Kubokun and only changed the CPU core count along with adding the GPU spoof. BTW before the Sonoma attempt the GPU Spoof was enabled and not causing an issue. The other things I changed was enabling the AppleDebugging quirk, unhid auxiliary, and set the picker to Full. I can also say I'm not getting any error logs output to the USB. I don't know why. I have verbose enabled. It's why I turned on the AppleDebug quirk. Didn't help. Anyway after these changes I now get nothing when I select install_macos.dmg in the picker. It does some processing in the background because the cursor doesn't move and neither does the picker menu. After about 30 sec. The cursor moves again and choices can be selected.
Can I get an experienced look at my EFI. I would appreciate it very much. Please and thank you.
