Hey guys,
I am relativley new to Hackintoshing and the first boot process to the Catalina installer constantly gets stuck on the aforementioned line.
After that it jumps to a strange apple Progress Bar, which you can barely recognize because you can only see the very beginning and very end of it. After that, it jumps to the installer with broken graphics and the cursor in the top left corner.
My specs are:
CPU: AMD Ryzen 5 3600 Six-Core-Processor
Motherboard: Gigabyte AORUS B550M Pro-P
RAM: Corsair Venegance RGB Pro 2x8 Gigabyte 3200MHz
GPU: NVidia Gigabyte GeForce GT730 1GB GDDR5
I have attached my config.plist. I am using trying to use OpenCore.
Best Regards from Germany and thanks in Advance
Arcann
IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0
My specs are:
Arcann
