msi x570 gaming edge wifi
chandru
how can I install Monterey in my psi x570 motherboard..always I get failed
Monterey does not work on MSI X570/B550 with newer BIOS. If you have a Zen 2 CPU you can downgrade the BIOS. With Zen 3 CPU you can't run Monterey.
h4kaya
Why? Is there any method to install it? Why can't msi a monterey be installed on an Asus motherboard with the same chipset?
shnyaps
I installed Ventura on my 5950x+MSI x570 Godlike(latest bios). I have to recreate config from the beginning.
wifi+bt don't work yet. I have to buy usb wifi dongle.
My old config worked like a charm in Big Sur (with wifi, with bt)
Moozuki
The MSI Bios is borked and the ASUS is not.
The board maker writes the BIOS, it is not part of the chipset.
h4kaya
Can we request Bios update from Msi? What's wrong with the bios? I can use Big Sur without any problem.
Thank you for replying
