Monterey 12.7.4
laurent
Hello everyone, a quick question is can I update monterey from version 12.5 to version 12.7.4 without having any problem?
Yes, that shouldn’t be a problem, assuming your OpenCore EFI is set correctly for your system.
The biggest change during the Monterey update process happened with the release of 12.3.x. So you are already past that point.
laurent
Thank you, I will try but I will make a copy of my system on another hard drive as a precaution
