sudo amdfriend --in-place --backup --sign --directories /Applications/Autodesk/maya2024/Maya.app/Contents
Thanks to Shaneee for the quick solution to my problem and the detailed instructions, it all worked!Yes amdfriend can patch it to run. Downloaded a torrent to test this out for you.
