Hi there!
I have running Sonoma. The OS itself is stable and have no problems with running. My main problem is that the sleep / wake does not work. Going to sleep is fine (it take little bit longer than I would anticipate), it stays asleep no problem. The problem is when I try to wake it up, the system reboots.
And second problem, not so significant for me (but would be nice if I could get solved), is that I when I try to boot Windows (11) from OpenCore I will only get black screen. The OS will boot, because I can hear Windows sounds but I only get black screen.
Specs.:
MB: MSI B450 Mortar Max (will update bios version, but fairly new)
CPU: 5800X
GPU: XFX RX6800
OpenCore version 0.9.9.
I would really appreceate any help.
Have a nice day, thanks!
Specs.:
CPU: 5800X
GPU: XFX RX6800
