- Joined
- Mar 13, 2020
- Messages
- 2,179
GitHub - AMD-OSX/AMD_Vanilla: Native AMD macOS via OpenCore
Native AMD macOS via OpenCore. Contribute to AMD-OSX/AMD_Vanilla development by creating an account on GitHub.
github.com
If you think you already have these then check your config for the following patch,
DhinakG - cpuid_set_cpufamily - force CPUFAMILY_INTEL_PENRYN - 11.3b1
If this is there then you're set to install 11.3. If not download the patches for your CPU and merge into your config.
Thanks,
