Intel HD Graphics 3000 in El Capitan(Glitches - white screen flickering problem chrome)
FTICET
I got these weird glitches on my hackintosh.......im already pissed of because theres no other option to fix it.
I Used the Rehabmans Laptop patches to get my gpu working....otherwise the kexts wont load.
I got a 7th series Chipset with a i3 2370m(sandy bridge cpu)
Ive downgraded to el capitan for less graphical glitches.......still.....they occour often..
Anyone can help me?
Add this to device properties for your iGPU,
<key>AddProperties</key>
<array>
<dict>
<key>Comment</key>
<string>Selects desktop HD3000 framebuffer</string>
<key>Device</key>
<string>IntelGFX</string>
<key>Key</key>
<string>AAPL,snb-platform-id</string>
<key>Value</key>
<data>
EAADAA==
</data>
</dict>
</array>
You may also need to fake the ID to 26010000
FTICET
How to do this on clover????? I cannot inject the copied file directly??? Should i use proper tree instead???? and where should i add the txt file?
You can still add device properties on Clover. If it's clover your using the FakeID becomes 0x01268086
