Installer not booting, Haswell E on chinese Mobo
divarak
14
Hello everybody, I am struggling with my new computer. Build everything using dortania guide, and make all pass through OCAT to assure results.. No luck. Always stuck and can't get to installer.
Please help.
Mobo: MAchinist X99-MR9a PRO MAX v1.2
CPU Xeon E5 2696 v3
Bios AMI 5.11
GPU: Radeon RX6600XT
Audio: Realtek 897
LAN: Realtek 8168
Nvme: Samsung 970 EVO Plus 2TB
Is CSM disabled in the BIOS? I've got the Machinist E5-RS9 for my Unraid setup and I can't disable CSM so no macOS on it.
Hello Shanee, it was enabled. But after I disabled and tríed again, this was the messages (using OC debug)
Try this,
Me again, after took the efi folder provided (Thanks to) by Shanee, switched back to opencore release.
I also made the mistake to overwrite files, but not clean all files before unzip.
Now, I am getting OCB: LoadImage failed - Unsupported
This is my actual EFI:
After checking, I made a BIG Mistake, my installer is for Ventura, not Sonoma.
The post can be moved? Should I post again on the right section? Apolgies.
Hello, Me again, stuck on another place now. Is there some workaround for Nvme? I also have another disk, SPCC M.2 SSD (silicon Power)
  • EFI14122023.zip
    EFI14122023.zip
Could Manage to make it run!!!!
Power Management isn't working and about Apple Servicies, well I don't use them.
But I think could be a good start point for anyone having this Mobo.
I want to thank everybody who helped me with this "batlle" hehe.
Regards.
Divarak
