Get the EFI from the work opf this guy https://forum.amd-osx.com/index.php...0-oc-0-7-6-big-sur-11-6-2-monterey-12-1.2400/, modify the config.plist for the correct (06) number of CORES (FX-6300) because his CPU had 8 cores and you are good to go.
That is what I did.
Of course you need to work on patching things to have Audio, etc., but your system should work.
That is what I did.
