Ritchwill
I have been trying for over a week not to create a working installer for MSI X570 Meg Unify with Ryzen 7 5800 XT without success. I can get it to the Big Sur 1st screen where I should be able to select drive to format or install. No options show just spinning wheel for a few minutes then crash. I have attached my panic report. Please please please assist before I lob the whole thing out of the window!!
Cheers guys
Ritch
  • opencore-2021-06-13-180607.txt
AudioGod
I will send you a new EFI to try.
Give me a few minutes and I will send it though to you. (y)
Ritchwill
Thanks so much buddy, much appreciated (y):D
AudioGod
@Ritchwill Here you go buddy.
Drop the EFI Inside the folder into your EFI Partition on your USB Installer and give it a try.
I had generated new SMBIOS Details for you so this should be plug and play.
Let me know when you have downloaded it so I can remove the link to stop other people using the Details I made for you.
Good Luck
AudioGod
Make sure you have Above 4G Decoding -> Enabled in the bios and CSM Mode Disabled.
AudioGod
If you downloaded the EFI before I sent this message then download it again as I made a small error that I have corrected now otherwise ignore this message.
Ritchwill
You are a diamond, downloaded buddy and just about to try it. Thanks and fingers crossed.
AudioGod
Good Luck
Ritchwill
Good Luck
No joy buddy, it gets to macOS Recovery, examining volumes, doesn't show disk util or install Big Sur just crashes at that point.
AudioGod
Maybe you should try recreating your usb installer In that case.
Ritchwill
Good idea, using a different 16GB flash drive. USB 3 for faster transfer
