[Help] Infinite NVMe Hang (AppleNVMe Assert failed) - Ryzen 5600X / MSI B550M
smeds
Ryzen 5 5600x
Hi everyone,
I'm trying to set up my AMD Hackintosh using OpenCore 1.0.7, but I am hitting a hard wall during the initial boot from the USB installer. The system completely hangs at the NVMe initialization.
I know the Crucial P5 (with the proprietary Micron controller) has a terrible reputation on newer macOS versions, but I wanted to see if anyone has a final workaround before I give up and buy a WD SN850X.
Hardware:
  • CPU: AMD Ryzen 5 5600X
  • GPU: ROG RX 6650 XT 8GB (Spoofed to 6600 XT via DeviceProperties + agdpmod=pikera)
  • Motherboard: MSI B550M-PRO VDH
  • RAM: 2x8GB Crucial Ballistix @ 3600MHz
  • Storage: 1TB Crucial P5 (CT1000P5SSD8) - Target Drive
  • macOS Version: 26.4.1
  • Bootloader: OpenCore 1.0.7
The Issue:When booting the installer, the log stops completely at:AppleNVMe Assert failed: 0 == (status) ErrorExit...virtual bool IONVMeController::start(IOService *)...There is no kernel panic backtrace; it just hangs there infinitely.
What I have already tried:
  1. NVMeFix.kext: If I disable NVMeFix.kext, the system actually Kernel Panics. With NVMeFix.kext enabled, it shields the panic but results in the infinite hang.
  2. APFS Trim: Set SetApfsTrimTimeout to -1 in Quirks to bypass the aggressive trim hang. (No change).
  3. Virtual Map: Toggled SetupVirtualMap to False due to B550 chipset quirks. (No change).
  4. Hardware Swap: Moved the Crucial P5 from the top CPU-linked M.2 slot to the bottom Chipset-linked M.2 slot to change how it presents to the kernel. (No change).
  5. AMD Power Kexts: AMDRyzenCPUPowerManagement and SMCAMDProcessor are strictly disabled in my config to prevent unrelated panics.
  6. BIOS: SATA is set to AHCI, NVMe RAID is disabled.
At this point, I am assuming the proprietary Micron controller in the P5 is just fundamentally incompatible with Apple's rewritten storage stack in Monterey+.
Has anyone successfully booted a modern macOS version on a standard Crucial P5, or is it time for me to buy a new drive and use an SSDT-NVME-DISABLE on this one?
I have used a Crucial P5 NVME drive as a macOS boot drive, without any issues. All I added was NVMeFix.kext, that was as an afterthought not because it was essential to macOS being installed.
I didn’t have to add any other kexts, patches, quirks or boot arguments to have this and a Crucial P3 NVME drive boot macOS Sonoma or Sequoia. Not sure which systems they are currently installed in but haven’t had any issues with them.
Not sure that helps you, as you are obviously not having the same luck/fortune as me with your Crucial drive.
All I can recommend is to remove/delete any patches, quirks or boot arguments that you have added or changed while trying to fix this issue. How long did you wait when the system/installation seemed to stall? Sometimes the macOS installation can appear as if it has stalled but it is not always the case, it can be slow or doing something in the background which you just need to allow to finish, before it will continue the installation process.
You don’t want or need a WD SN850X drive for your B550 mATX motherboard, as it won’t use the full potential of the drive. You would be just as well served using a WD SN570 or SN770 drive. Given the stupid prices being asked for NVME drives these days, you are likely to be scalped or robbed blind, buying any M.2 NVME drives.
Do you have any other drives connected to your system while installing macOS? If yes, try disconnecting them from the system, see if that helps.
Are the PCIe lanes from the bottom M.2 connector shared with the SATA ports? Your motherboard manual should confirm if this is the case, and how to configure the connector and SATA ports to make best use of them. The bottom M.2 connector often has a Bios setting that allows it to run in three modes: ‘Auto’, ‘x2’ or ‘x4’.
If there are SATA drives connected to SATA ports 5 &/or 6 then the bottom M.2 connector might be working at x2 speed instead of x4 speed. This Might be a reason why the Crucial drive has issues, if the relevant SATA drive(s) are populated. Using the top M.2 connector is best option, as that connector won’t be sharing its PCIe lanes.
Bottom system in my signature contains the Crucial P3 Plus NVME drive, a similar B550m system., but using an Asus motherboard.
Here is an OpenCore EFI v1.0.5 which I created for another user who had a very similar system to yours. MSI B550m Pro VDH WiFi / Ryzen 5 5600X / RX 6600 XT.
I have amended it to suit your system, MSI B550m Pro VDH / Ryzen 5 5600X / RX 6650 XT as best I can, without having the system to hand.
I have added these elements to the attached EFI from your OC setup:
  1. USBToolBox.kext & UTBMap.kext. I have assumed these are correct.
  2. MacPro7,1 SMBIOS data. I have assumed you tested this on the Apple Support page and it is not used by a real Mac Pro.
I have changed WhateverGreen.kext for NootRX.kext, which natively supports the RX 6650 XT GPU. So no need for spoofed ID or agdpmod=pikera boot argument.
I have not included the SSDT-BRG0.aml table, try booting without it, as I am not sure it is 100% correct for your system. It is not essential to your installation of macOS.
I have not included any Sensor kexts, as again these are not essential for installing macOS and are as likely to cause issues with macOS as they are to resolve any.
Try installing macOS Monterey with this EFI and see how you get on. It should work in Big Sur, Monterey, Sonoma and Sequoia without the need for any edits.
