Hello! Looking for help to get Big Sur or something else working
Cybergy
I have been working with Home-based pro-audio since the start of the pandemic. For various reasons (Garage Band, etc) I would like to try out ANY version of MAC OS that is supported. I'm looking for a straightforward setup guide - anyone?
Your GPU limits you to running macOS High Sierra, as your GTX 1060 requires the Nvidia Web Drivers if your system is to run with full graphics acceleration.
You might want to expand on the Motherboard and CPU descriptions, as what you wrote in your signature could be anything FX related.
Have a read of this guide I put together for an FX8350/Asus 990FX Sabertooth 2.0 system:
It should give you a heads up as to what is required for Hacking an old FX system.
