Gigabyte A520m-DS3H Ryzen 7 5800x RX5600 xt
Updated to OC 0.9.9
Updated to latest kexts
Updated to macOS 14.4
Had to disable power management kexts, openintelwireless kexts, and all bluetooth kexts, was then able to update from software update.
After update upgraded to newest 2.3.0 openintelwireless kext and re-enabled power management kexts and upgraded to version 2.4.0 of the bluetooth kexts.
Wifi works, bluetooth doesn't. Will try remapping USB, not sure what else to try.
Reactions: Edhawk
Bluetooth now works, Thanks Shaneee!
Updated to 14.5 Beta.
Reactions: Edhawk and Shaneee
Updated to 14.5 Beta 4 with no problems from Software Update. No changes to EFI required.
Updated to Release 14.5 and OC 1.0.0, no changes needed.
I did have to disable Ryzen power management and wifi/bluetooth kexts to get process to complete thru software update,
Reactions: fullfunk and Edhawk
Hello Sir, Could you post your current EFI , im trying to install Sequoia 15.4.1 i can go into recovery image then i install it transfers to the ssd then reboots goes into another install but after that keeps rebooting no matter what.
I'm sorry to say there is no longer an EFI for this machine. Bios update rendered it unable to boot any combo of OC/macOS. This is still my main rig but it only runs Linux Mint now.
Can't you reinstall the Bios that previously worked?
Is there something in the new bios that is essential for your system, so that you can't run the system without this Bios update?
Reactions: ccphuc
