- Joined
- May 9, 2023
- Messages
- 15
Hi,
I have a mac mini and a hackintosh and i want to connect them via thunderbolt bridge to get 40GB/s. The hackintosh acts as my file server/Workstation. This basically acts like my storage server instead of getting a TB4 enclosure with limited storage capacity. currently i m using 10Gb/s network Card. But things are getting a bit slow when doing file transfers and loading image/videos. Hence the upgrade to the thunderbolt to get maximum bandwidth between my mini and hackintosh.
My hack specs
Mobo: Aorus Master X570 Rev 1.1(confirmed by checking for THB_C header on the mobo)
CPU : 5950x
RAM:64 GB
GPU: 6800 XT
MacOS: Ventura 13.2
Is it possible if i get the GC-Titan Ridge 2.0 card, i can connect them via thunderbolt bridge to get 40Gb/s bandwidth?.
Also do i need to flash the Titan ridge card?. Can it work with my mobo(plug and play).
Thanks.
My hack specs
CPU : 5950x
RAM:64 GB
GPU: 6800 XT
MacOS: Ventura 13.2
Thanks.
