Freezes at ACPI: 18 ACPI tables successfully acquried and loaded
XOM
What system are you using?
Which EFI folder are you using?
If you are using a B550 motherboard it requires the SSDT-CPUR.aml table to be added to the/EFI/OC/ACPI folder and a corresponding entry in the ACPI section of the config.plist.
See this link to the OC troubleshooting guide - # Struck at ACPI table loading
