First OS X Install
crazychristie
AMD OS X Rules: # AMD OS X Discord Server Rules * Be nice to each other. * No pirate links, no warez talk. * Please try to keep the language clean. * Don't interrupt active help sessions. Look for a free channel (install_support and post_install_support are self-explanatory, if those are in use, use one of the misc_hackintosh channels). Breaking this rule will result in a warning/mute/kick. * Don't cross post your issue across multiple channels * ‎Don't PM or ping anyone for help if they don't ask you to do so. * Promotions are generally not allowed without moderator approval (you can of course link to another server if they would be able to offer better support for a specific issue - say for example, linking to the Intel hackintosh server for Intel hackintosh support or the Microsoft server for Windows support). When in doubt, message a mod. * Don't use Multibeast/Unibeast. * Distros are not supported here. This includes AMDHS, HighSierraAMD, etc. - those are no longer supported. Use vanilla. * If you care about your serial number, hide it when taking screenshots and send your config.plist via PM. * If you don't have anything useful to say then just keep it to yourself. * Moderators have the final say. * Enjoy your time on this server!
I'm running Ryzen 9 5900x RTX3060 and Gskill Ripjaws 32gb 3600mhz ram, gigabyte 570 elite motherboard. Will this system run AMD OSX or not really? Any help is appreciated thanks.
Successfully completed my first OS X installation! The process was smoother than expected, and everything is running well. Excited to explore the features and get everything set up. Looking forward to a stable and efficient workflow on this new system.Up Bhulekh
Reactions: Edhawk
Successfully completed the first OS X installation! The setup process was smooth, and the system is now up and running. Looking forward to exploring its features, customizing settings, and seeing how it performs in daily use. Exciting new journey ahead.
The experience of the first OS X install is memorable for any Apple user, combining simplicity with powerful performance. The installation process is smooth, guided, and user-friendly, even for beginners. From the clean interface to the quick setup tools, everything feels polished and intuitive. Once the system boots, you instantly notice the speed, stability, and elegant design. Overall, the first OS X install leaves a lasting impression of quality and efficiency.
