Hi, I was able to install and boot Catalina on my GA-970 UD3P/FX 8300 just fine. Most of what I need is working. But it needs some fine-tuning.
-After shutdown, the system doesn't turn itself off
-Sleep not working. The system goes to sleep, but at wake, it freezes. I know it can work, it worked with Sierra/Clover before
-Is there a way to get power management working on FX processors? AMDRyzenCPUPowerManagement.kext will most likely not work on platforms older than Ryzen, right?
Edit: Attached EFI
Edit: Attached EFI
