Fenvi T919 Bluetooth...Blues.
I’m wondering if it’s because f95zone the system is using the X570 Intel euwatchBluetooth over the Fenvi.
You may have a conflict while both BT devices are present and enabled.
Can you disable the Intel device in your system BIOS?
Can you physically remove the Intel WiFi/BT card, as that is usually the best long term option.
