ERROR [EB|#LOG:EXITBS:START] when updating from Catalina to Big Sur
Ignoto10
Hi, I have never been able to install Big Sur, with any efi, while instead wandering the internet.
I found someone else's efi based on ryzentosh, based on Catalina. But I was never able to get patches to work, so I made it work without them.
If I upgrade from Catalina to Big Sur, the log tells me OC: Kernel patcher result 17 for kernel algrey - cpuid set cpufamily - force CPUFAMILY INTEL PENRYN not found.
If I enclose my efi, someone can help me, I've been beating my head for a month to create a stable hackintosh, but I can't, I have performance problems on final cut.
Thanks to who helps me EFI : https://drive.google.com/drive/folders/1v68co93nVAJlGOFIrApGruPdCDAAMd-6?usp=sharing
Motherboard Asus prime x399a
Cpu AMD Ryzen 1920x Threadripper 12 Core 24 Thread
GPU Asus rog strix rx 590
Ram Hyperx Fury 2666 mhz 32 GB
mx850 corsair power supply
Try this OpenCore EFI based on OC 0.7.9 adapted for a 12-core AMD CPU, running Big Sur or newer.
See if this gets you to boot macOS.
Ignoto10
I pasted the EFI in the usb, I still have catalina, so I update Big Sur with your EFI on my USB, but as soon as I select update mac os installer, the pc turns off completely. How is it possible?
No idea why that happened, as I don't know how you have created your USB installer.
