Efi files for Gigabyte b450 Aorus Elite | Ryzen 5
Help you do what exactly?
You need to confirm the following:
  • Which CPU are you using?
  • Which GPU are you using?
Questions:
  1. Have you created an OpenCore EFI for your system?
  2. Have you set the Bios to work with macOS?
  3. Have you created a custom USB configuration for your system, in Windows?
  4. Are you too lazy to have done any of the above?
