Discord Noise Suppression on Ryzen based Hackintosh
vortex
Ryzen 5 3600XT
Hi all, I noticed that discord has some issues under macos running ryzen for which I have found fixes that have corrected it for the most part. When using these patches everything works fine but the noise suppression. I also saw there are krisp ai fixes for ryzen too though krisp requires you to pay to have more than one hour a day for noise suppression. Is there a fix to keep discord working and the noise suppression as well. Thanks in advance.
I believe AMDFriend may be able to fix this. I've tested the command and Discord still seems to function as normal but I've no way to properly test the noise suppression.
Bash:
sudo amdfriend --in-place --backup --sign --directories /Applications/Discord.app/Contents
