Cpu disabled in vmware
jeremy0519
I attempted to install catalina in vmware according to the instructions on the knowledgebase. When the installer rebooted, I keep getting the error that cpu is disabled in guest machine (something like that). My cpu is Ryzen.
larryking123
Hi
You have to make sure that the VMware version is 15.5 if you are gonna use the image from here. Or use VMware 15.03 and use other vmware images. Make sure the unlocker is working as well.
larryking123
Hey
blow away you vmx file or just start over and create a new VM machine. It corrupted
Don't switch between Microsoft and MAC.. Just start out with MAC OS from start to finish
Maclover999
I attempted to install catalina in vmware according to the instructions on the knowledgebase. When I the installer rebooted, I keep getting the error that cpu is disabled in guest machine (something like that). My cpu is Ryzen.
I have the same issue
Cocoz
I hade the same problem. For me it was the pre install code that I entered wrong.
Oops, was so in this, fixing vmware hackintosh, so I missed that last message was in July....:)
