config AMD 5950 + B550 vision D + radeon VII
Status
Not open for further replies.
maclinuxg4
hello i start to swtiff on AMD with mojave (10.14.6)
First i will use my usb key for my previous install.
May be i will try mojave gibMacOS.command from the gibMacOS-master folder.
i get opencore 7.2 from csasey (tonymac), any help is appreaciated to adape EFI for mojave
Thanks for any help
maclinuxg4
nice i continue after installer, it is important ot use a RX580 radeon to raise installer, then the install continue
on my NVME.
il ost BIOST boot, (NVME seems to not be acknowle properlly
tomorow window will be install too
maclinuxg4
is possible to help for movaje ( deactivated if Catalina / Big sur part only in config.plist) ?
Status
