Compatibility check - Ryzen 7 2700x, Gigabyte Aorus Ultra Gaming, GTX 1070
DeenCaecus
Hey folks,
I just thought about trying to get into the hackintosh world again. I didn't knew, that it is actually running on amd aswell, so I stop looking for it since I switched from an intel to amd...
I hope you guys can help me, if this system is compatible. Woud love to know, if it's hard or rather easy to install. I work as an IT-Sysadmin, but never got a working hackintosh running, nor I got experiance with mac OS. A reason why I'm interested to use it, since I can educate myself while using it :)
CPU: Ryzen 7 2700x
Mainboard: Gigabyte Aorus Ultra Gaming
GPU: GTX 1070 KFA² HOF
RAM: 2x 8GB G.Skill Trident Z
SSD: 2x NVMe, 2x Sata
Would love to install it as a dual boot next to my Windows 10.
Looking forward to your answers :)
Deen
wild_eep
GTX 1070 is only supported up to MacOS High Sierra 10.13.6. If you don't care about GPU horsepower, an Nvidia GT710 is dirt cheap and fully supported in the newest versions of MacOS 10.15.x. GT710 will work out of the box without any need for special configuration or kexts.
GPU Buying Guide for Hackintosh
