Catalina 10.15.4 Crash after GTrace Synchronization Point 3
mo3r99
Hi everyone!
I created a USB installer using the guide at vanilla.amd-osx.com and it installed fine, but when I booted to the hard drive that I installed it on, I get a crash after 'GTrace Synchronization Point 3', after which it reboots and the cycle continues. The installer USB boots fine and I can also boot to recovery from the hard drive, but booting actual macOS results in a crash.
I'm using Opencore 0.5.8 on an FX-8320 and Gigabyte GA-970A-DS3P motherboard, with an Sapphire RX 580 4GB. I have attatched my EFI if it is needed. Thank you in advance!
    EFI.zip
I figured it out. Turns out I had an old hd 5450 in my pc that I completely forgot about for some reason. I removed it and it booted up just fine!
