Hi, this is my first hackintosh I'm trying to do.
My components are:
I followed a simply tutorial made by TechTunerLife on YT, using Opencore 0.5.6 and Catalina 10.15.4 (recovery only)(full install)
I think I've done everything correct, I can boot Mac os installer via USB, prepare the hdd, but I can't continue installation because
1. I have not LAN cable
2. Probably my tplink pcie is incompatible
3. HoRNDIS kext maybe doesn't work for me
For the first two problems I thinks there isn't much that I can do, so I've tried to use HoRNDIS kext to connect my Redmi Note 7 Hotspot to Mac via USB tethering, but still not working. I get "An internet connection is required..."
Maybe I've done something wrong during horndis kext installation? I've extracted the pkg with 7zip and then copied horndis kext into the correct folder, turned on pc, booted with Mac installation, and then connect tethering usb
Can I solve this problem by installing macOS in offline mode, using opencore?
I apologize for all this problems, I hope you can help me as soon as possible
My components are:
- ryzen 5 1600
- rx 570 4gb xfx
- msi b450 tomahawk max
- 2x8gb ram adata spectrix d41 2666mhz
- tplink archer t4e (Realtek)
