Can I enable WIFI6 on an intel AX210 in Ventura?
askunk
So far this is the only info I could find on it, but it's dated and no confirmation if it works.
Does anyone know if there is any chance to move to 802.11ax with Ventura?
I am using Airportitlwm 2.2.0.
Thank you.
Support for AX210 (MVM Gen3) family of devices was added to Airportitlwm.kext and Itlwm.kext in release 2.1.0 Stable.
So you should only need to make sure you are using the correct version of Airportitlwm.kext, I.e the specific Airportitlwm.kext for Ventura.
askunk
Hello Edhawk. Thank you for being here every time. Very kind of you :)
I have the 2.2.0 stable, the latest.
System info says:
Supported PHY Modes: 802.11 a/b/g/n/ac
Do the data refer to the router or the wireless card? If it's the former, then I'll need to wait for the new router (ax) to verify it and it might work.
Handoff and Universal Clipboard work only from iPad or iPhone TO hackintosh, not vice versa (any fix for it that you know of?)
Thanks again
Intel WiFi/BT cards don't provide all the Apple Continuity features. This is a well known issue with Intel WiFi/BT cards and both kexts. Depending on which kext you use dictates which continuity features are available.
This is what the Itlwm docs say about Airportitlwm.kext
Limitation of AirportItlwm.kext​
Have a read of the Itlwm FAQ for more information.
askunk
Thanks. I read all the docs before coming to the forum. It says Uni Clipboard is supported but on mine works one way only.
It may be normal, they don’t go in such details, but it seems it woks fine to others.
askunk
As per the ax, there are mixed and dated info. I guess it’s not reliable yet. I don’t seem to find success stories.
Reliable, no not to my knowledge. But that is one of the many compromises that using an Intel WiFi/BT card requires.
