Budget ryzentosh build for general use (first time builder)
rama3122
Hi
I am planning to build a budget ryzentosh to use mainly for basic work use like surfing the web, word processing,etc but also plan to dual boot linux since i am trying to get into penetration testing too. I don't do any gaming but will probably need a seperate GPU too for the penetration testing. What do you think of the build below? Are there any obvious glaring issues or things i could improve upon? Thanks in advance
PCPartPicker Part List: https://au.pcpartpicker.com/list/G8tfK4
CPU: AMD Ryzen 3 3300X 3.8 GHz Quad-Core Processor ($265.00 @ Amazon Australia)
Motherboard: MSI B450M PRO-M2 MAX Micro ATX AM4 Motherboard ($167.13 @ Amazon Australia)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($114.00 @ Amazon Australia)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive ($159.00 @ Amazon Australia)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card ($347.40 @ Amazon Australia)
Case: Deepcool MATREXX 30 MicroATX Mini Tower Case ($58.79 @ Amazon Australia)
Power Supply: Cooler Master MWE White V2 230V 550 W 80+ Certified ATX Power Supply
Monitor: Dell S2721DGF 27.0" 2560x1440 165 Hz Monitor
Generated by PCPartPicker 2020-09-20 12:00 AEST+1000
AMD will announce Zen 3 in a couple of days and then the new Navi 2x GPUs two weeks later. If you don’t need it now I’d wait for the new hardware if only to get your selection a little cheaper
Ok thanks for the suggestion, i'll definitely wait then
