Boot problem //Asus Prime x570-Pro//Ryzen9 3900x
S3il3S
5
Hey guys,
I've been trying to install Catalina but the loading just stops randomly at some point after i select boot macOS in OC menu. but the last thing in the debuging txt file is always 21:076 00:023 OCSMC: SmcReadValue Key 4D534163 Size 2.
bevore the OC menu pops up i get a fail : "00:578 00:023 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82: prev-lang:kbd - Not Found" is that a problem?
I've never worked with OpenCore before so help would be great :D
I've got passt this point by adding npci=0x2000 directly after -v.
but now then the pc restarts after the instalation i get a Blackscreen with the information. that i have to plug my cabel in...
"ROM = 112233000000 You should set this to your NIC MAC address. See PlatformInfo Docs " This is the only suggestion i get.
The blackscreen was just the sleep mode i couldn't wake up from. (working fine now).
but now when the Installer restarts it starts into my Windows and doesn't continue with the installation. any ideers?
it took a very long time on the 2 min remaining mark and the debugging console showed that the sidecaruli framework's couldn't be loaded.
I will try if its working when i unplug my Windows m.2ssd
Worked flawlessly after removing the m2. hope there comes a fix for sidecar that would be awesome. But as long as nobody finds a way to use the normal GPU instead of the IGPU.
