Bee-Link GTR7 Mini PC - Installation Help
Praneethvc19
AMD Hybrid Phoenix Ryzen 7
Hi guys,
I'm new to the community and i'm trying to have my Mini-PC running macOS Sequioa to get a start in the macOS world and probably get one down the line. I've been having bad luck when trying to install, i tried every tutorial and followed the instructions with no success.
Config:
CPU: AMD Ryzen 7 - 7840HS/w AMD Radeon 780M (RDNA3/Phoenix)
Network: Intel 1225V & Intel Wi-Fi 6 AX200
I've had rooted.kext, SSDTs and everything that was mentioned in the Dortania Guide but it just pops a error - ([EB.LD.LF | IN] 0 1 <"<null string>"><"1">) everytime when i boot to install the macOS. I'm not sure if the BIOS settings are messed up, but i've disabled the 'Fast Boot', 'Silent Boot' and i can't make changes to the SATA Configuration as it just shows me IDE Configuration with no option to customize or with options when i select the SATA Config. Please help me if i'm missing something or if it's even possible to have it with this CPU. Appreciate all y'alls help.
Your AMD iGPU(780m) isn't supported by NootedRed.kext, so it will never have full graphics acceleration.
The system if you got it running macOS would probably glitchy and with low resolution.
The only 7000-series CPU's compatible with macOS are the 7x30 processors, i.e. Ryzen 5 7530u and similar. As these CPU's use the older Radeon Vega iGPU.
Ah! Damn! This sucks! WIsh it had support, maybe i'll just get a different one with Intel Chipset and try. Thanks @Edhawk.
Reactions: Edhawk
The only 7000-series CPU's compatible with macOS are the 7x30 processors, i.e. and similar. As these CPU's use the older Radeon Vega iGPU.
do you have a efi for Ryzen 5 7530u?
Yes, a copy of the EFI is attached below.
It was created specifically for the GenMachine Ren 7000 system running macOS Ventura, so it would need editing to work correctly with another mini PC system and/or a newer release of macOS.
I have removed the Serial Number, MLB, ROM and SystemUUID entries from the config.plist, as they are still used in my system. You will need to provide your own for the iMac20,1 SMBIOS.
I was using an Intel WiFi/BT card when this EFI was created, so it contains Itlwm.kext and the Intel Bluetooth kexts. It also contains a country-code Boot argument.
You can use this EFI as a base point for creating your own EFI. I would not recommend using it on another Mini PC as it stands.
